1. AC Question's Avatar
    My phone had to be sat down and left so it was very still. After one hour it only had eight percent charge.I pushed the little tongue up and it did good for about 30 minutes no vibrating or the battery low beeping. It held charge for 10 minutes. My husband changed the port ( never done that) now it just vibrates like its going to come on but won't. Also the little strip on the back is pink.A friend gave it to me so not sure what the story on that is.
    04-29-2016 05:29 AM
  2. belodion's Avatar
    Ask your friend whether it has been water-damaged.
    04-29-2016 06:27 AM
  3. Rukbat's Avatar
    First mistake. He broke something or failed to reconnect something. Now you have to find a repair shop willing to fix someone else's mistake. (Very few legitimate ones do, because anything could break down a week after you get it back and you'll blame them - when it's your husband's fault.)
    It's never been wet. If it gets wet, the strip turns white.
    belodion likes this.
    04-29-2016 04:38 PM
  1. Mobile is getting charge only if battery is less than 60%
    Last Post: 04-29-2016, 04:41 PM
  2. Replies: 1
    Last Post: 04-29-2016, 03:27 AM
  3. my laptop can't see files on my galaxy tab2
    Last Post: 04-29-2016, 03:12 AM
  4. Replies: 0
    Last Post: 04-29-2016, 02:13 AM
  5. Does my Galaxy 6 active is able to take an SD card
    Last Post: 04-29-2016, 12:49 AM
