1. AC Question's Avatar
    I was using my phone outside with my mobile data on and I felt that my phone was hot (not too hot because i've encountered some days that it was too hot) and while using it with my powerbank on (which halfway lose its energy) my phone shut down by 3%. It was unusual because it turns off by 1%. When I got home, I tried charging my phone with my charger but then nothing showed up even the LED or Battery sign. So i'm like "okay i should buy a new cord" because it looks faulty. I bought a new one but then still the same problem. What should i do?
    04-30-2016 05:15 AM
  2. belodion's Avatar
    One possibility is that the battery has failed.
    04-30-2016 05:33 AM
  3. I Eat Pears's Avatar
    hello, im the one who posted just now. is there any solution rather than spending money?
    04-30-2016 06:09 AM
  4. belodion's Avatar
    Welcome as a new member.
    I'll pass this in for more possible suggestions.
    04-30-2016 06:48 AM
  5. sydneycooper1979's Avatar
    I know you don't want to spend money, but it does sound like you need a new battery. Luckily Note 3 batteries aren't as expensive anymore. You should be able to pick one up on Amazon for a decent price. Good luck!
    04-30-2016 09:33 AM
  6. Golfdriver97's Avatar
    It does sound like a battery problem. However, have you tried a different wall plug as well?
    04-30-2016 09:44 AM
  7. I Eat Pears's Avatar
    hi im back again. unfortunately, there is no problem with the battery. they tried testing my battery and they said there's no power. they also tested another battery on my phone and still, no signs. so it could be a LCD or any hardware issues. hope not.
    04-30-2016 09:13 PM
  8. I Eat Pears's Avatar
    yes, i tried it already but it's still no use. tried different chargers, still no sign.
    04-30-2016 10:11 PM
  9. B. Diddy's Avatar
    Welcome to Android Central! Have you tried charging on a wall outlet overnight, without disturbing it? If you drained the phone to zero (or near zero), it might need an extended charge before it holds enough juice to power on.
    BTW, that avatar is hilarious!
    05-01-2016 12:38 AM
  10. I Eat Pears's Avatar
    hi there! i didnt tried charging it overnight but i charging it about 30-45 mins. Nothing showed up except that the back part of my phone is warmer than usual. anyways, i want to try charging it overnight but its still under repair. maybe if the price is too big for repair, i'll try to figure it out myself.
    and also, thanks for the compliment on my avatar. 😂
    05-01-2016 08:26 AM
  11. Rukbat's Avatar
    If the battery is totally dead it'll take about an hour on the charger before it starts charging, so 30-45 minutes won't do anything. Also, you shouldn't discharge the battery below 40%. Lithiums aren't deep-discharge batteries.
    Id sounds, however, as if something went on the motherboard, causing the heat. If so, that would mean having a new motherboard installed (which wouldn't pay, because you can buy a good used Note 3 for about the same price).
    B. Diddy likes this.
    05-01-2016 11:18 AM
  1. how stop the software auto update
    Last Post: 06-10-2016, 11:49 PM
  2. Replies: 1
    Last Post: 05-01-2016, 11:22 AM
  3. How to get rid of corner thingy on galaxy s5
    Last Post: 04-30-2016, 09:03 AM
  4. how do i find my clipboard on my galaxy core prime
    Last Post: 04-30-2016, 04:58 AM
  5. Replies: 0
    Last Post: 04-30-2016, 03:40 AM
