1. AC Question's Avatar
    Hello. I've been having problems with my phone after replacing broken screen. The phone works fine, I have signal and everything works fine, but I have a problem with wireless. I can use wireless,but the range is absolutly terrible. If I am located more than 5m from my router the wireless signal cuts and if I'm located right next to it, I'll have about 4 out of 5 bars. So I suspect the problem is with wireless antenna, but where it is located and what should I do to fix this problem?
    Thanks
    04-30-2016 01:25 PM
  2. Rukbat's Avatar
    Please don't duplicate posts.
    05-01-2016 04:25 AM
  1. My LG S3 is Locked
    By 072511 in forum LG G3
    Last Post: 05-01-2016, 01:25 PM
  2. IMEI problem in my Galaxy J7
    Last Post: 05-01-2016, 04:24 AM
  3. My mms on my lg says transmission failure wi try later
    Last Post: 05-01-2016, 04:23 AM
  4. Replies: 0
    Last Post: 04-30-2016, 11:32 AM
