1. AC Question's Avatar
    I have bought a Galaxy S7 from eBay I have used it for a full day with no problems after doing a factory reset first I have just set up my thumbprint fingerprint scanner for security and enter the password my phone has now locked me out and he's not asking for a password please can someone help
    05-02-2016 01:55 PM
  2. H3aTeRzz's Avatar
    Hi
    You will have to use Google's "Android Device Manager" or Samsung's "Find My Mobile" (assuming you had either of them activated) and change the lock code on your device. If you cannot get it to ask you for a password, then I'm afraid there's not much more you can do, other than to Re-Flash the software.
    Flashing the software requires you download Odin, and also download the original software for your device, from Sammoible.com
    Hope this helps!
    Chris
    05-02-2016 02:00 PM
  1. Why does the android YouTube app not show how many likes a comment got?
    By One_Ummah6789 in forum Android 6.0 Marshmallow
    Last Post: 09-06-2016, 09:22 AM
  2. Contacts has stopped
    By Daniel Davis4 in forum Samsung Galaxy Note 4
    Last Post: 05-02-2016, 11:30 PM
  3. Setting up a same contacts directory in 200 mobiles
    Last Post: 05-02-2016, 07:07 PM
  4. Replies: 2
    Last Post: 05-02-2016, 04:32 PM
  5. Galaxy S III touchscreen problem.
    Last Post: 05-02-2016, 02:29 PM
