1. AC Question's Avatar
    I am using micromax android one. the phone is currently running on stock android version 6.0.1. Suddenly without any reason i am facing battery life issues of getting it drain fast. When i went in settings and than in battery menu than i saw the graph of battery usage. when i went for further details i found that the phone was awake all the time even it showed that screen on time was 0 minutes. I faced this issue before when the phone was running on 5.1.1. After than when i updated the phone to marshmallow 6.0, the problem was solved and i got normal battery life. So that time i thought that it might be the issue of the 5.1.1 OS. But now after seven months i am again facing this issue. So tell me that is this fault of OS or any other issue?
    05-07-2016 02:36 AM
  2. SooHooStuff's Avatar
    What phone is this?
    05-07-2016 02:44 AM
  1. Replies: 2
    Last Post: 05-07-2016, 06:15 PM
  2. Replies: 1
    Last Post: 05-07-2016, 04:52 AM
  3. Replies: 0
    Last Post: 05-07-2016, 02:22 AM
  4. phone looping on reboot
    By Aniket Tyagi in forum Samsung Galaxy S4
    Last Post: 05-07-2016, 01:00 AM
