1. AC Question's Avatar
    My s5 works properly on -91dbm and receives all calls and msgs .. but my s7 edge is showing no network at same same spot on same sim and same reception -91dbm ? does s7 edge needs more reception to work ? or its antenna is inferior?
    i am using the one with exynos processor
    05-08-2016 01:14 PM
  1. Big Reception Issue on s7 Edge ???
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 01-24-2017, 12:30 PM
  2. why usb cable not connect in hi suite
    Last Post: 10-12-2016, 12:59 PM
  3. Is it true that the samsung s6 edge cannot take screenshots?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 05-13-2016, 09:53 PM
  4. Replies: 1
    Last Post: 05-09-2016, 02:10 PM
  5. Is it true that the samsung s6 edge cannot take screenshots?
    Last Post: 05-08-2016, 12:25 PM
