1. AC Question's Avatar
    I have several usb chargers. I have never had an issue with them before. I had left my phone in the car when I had to go to work today, Sunday, at 8am til 4pm, but I was able to move my phone from my car to the work place due to an Alert I was given that I could not use my phone when it is overheated. I tried plugging it in to one of my usb charger for it, but it said that it was unable to use the cable. I have a Samsung Galaxy S3 Note. Again, I have never had this problem. And I think that my phone up graded to the new version of the lollipop system, 5.0, which is good except of charging difficulties. I need to charger my phone because that is the only phone I have to get into contact with my mother and my work place. Please help.
    05-09-2016 12:18 AM
  2. sfoLAX's Avatar
    Hello. Did you only have difficulty charging because the phone was hot.
    If you take the battery out and lay it on a flat surface to spin it around, there may be a bulge which means you need to change the battery.
    If you install a good battery monitoring app like GSam it will warn when it is getting or staying hot.
    Was it very hot for 8 hours in the car. You may have had other heat damage or usb port damage.
    Please register to post here again.
    05-09-2016 05:54 AM
  1. sound and vibration problems
    By NiffiIsenguard in forum Samsung Galaxy S6
    Last Post: 05-09-2016, 03:26 PM
  2. How to Enable SD Card in Spice MI 498/Android 1
    Last Post: 05-09-2016, 10:26 AM
  3. Have an htc desire and need to bypass google verification
    Last Post: 05-08-2016, 11:39 PM
  4. Any way to turn on location mode on the android remotely?
    Last Post: 05-08-2016, 10:51 PM
  5. Should I upgrade from HTC One M7 to HTC 10?
    Last Post: 05-08-2016, 10:26 PM
