1. AC Question's Avatar
    normally my charger charges 1% in 1 minute but from 2 days its charging is very slow I power off the phone, took out the battery and then hold power button to remove charges then I power on the phone and find out that charging rate is normal again. so whats the real problem?
    05-09-2016 01:07 AM
  2. STARGATE's Avatar
    If you have a chance, try with a new or different battery.
    You can also try a factory reset on the phone, just remember to save all your data from that phone into an external source before doing the reset.
    05-09-2016 07:39 AM
  1. Samsung Galaxy S6's recent apps button not working?
    Last Post: 05-09-2016, 04:57 AM
  2. galaxy s6 battery drain
    By ryanp2011 in forum Samsung Galaxy S6
    Last Post: 05-09-2016, 03:28 AM
  3. Replies: 0
    Last Post: 05-09-2016, 12:33 AM
  4. Replies: 0
    Last Post: 05-09-2016, 12:09 AM
  5. Caller name is not displayed for +61....... numbers
    Last Post: 05-08-2016, 11:55 PM
