1. AC Question's Avatar
    I took Verizon's Galaxy S7 upgrade this morning and I have several problems. Touch screen seems to have lost its sensitivity and my keyboard is now almost impossible to use - keeps trying to give me multiple language letter/symbol options as I try to use. Impossible to type anything. Is there a setting that I now need to set? I did disable DTIgnite
    05-10-2016 07:18 AM
  2. the tall guy's Avatar
    Hi, what keyboard are u using, the stock one or a 3rd party one?
    05-17-2016 03:13 AM
  3. chanchan05's Avatar
    What apps have you installed as well, and from what sites?
    05-17-2016 05:15 AM
  1. Replies: 1
    Last Post: 05-17-2016, 03:10 AM
  2. having problems with my andriod tv box
    Last Post: 05-17-2016, 03:07 AM
  3. Does the HTC 10 for Verizon have VZW branding from HTC.com?
    Last Post: 05-14-2016, 08:00 PM
  4. Replies: 2
    Last Post: 05-10-2016, 10:56 AM
  5. Replies: 1
    Last Post: 05-10-2016, 10:50 AM
