1. AC Question's Avatar
    So i recently had super low battery left on my phone and attempted to switch to the Ultra power saving mode. Somewhere between switching, my battery went flat and i had to go back to charge it.
    When i switched it back on, my home and apps all seem to be appearing like they should, with exception of some widgets and apps, that are either black or not responding.
    The settings however, only showed the bare minimum like how you would see it in the UPSM mode. There is also no way for me to disable the UPSM mode when i swipe down and it just shows me the date and time and NO OPTIONS.
    I'm really trying to avoid the factory reset method because i have data in there that are quite important. If there is a way to beat the system and let me disable without doing much damage, that'd be great.
    05-11-2016 07:22 AM
  2. chanchan05's Avatar
    Settings>Battery>Ultra power saver mode toggle
    05-11-2016 07:43 AM
  3. Diana Basil's Avatar
    unfortunately, my settings only show the those that would be shown during the u.power mode
    like so:
    Alternative ways to switch of Ultra power saving mode?-screen-shot-2016-05-12-12.42.17-am.png
    and when i try to drag down the notification bar to toggle the disable, it's not there.
    05-11-2016 11:44 AM
  4. Tim1954's Avatar
    Turn off phone. Charge battery fully. Turn on phone in recovery mode... try that... check your settings, you may have turned the upsm on by default when battery reached a preset limit...
    05-12-2016 01:17 AM
  1. What is the best way to setup google for work email?
    Last Post: 05-13-2016, 12:48 PM
  2. Replies: 1
    Last Post: 05-12-2016, 03:20 PM
  3. Turn off LED in Do Not Disturb mode
    By Mugenized in forum HTC 10
    Last Post: 05-11-2016, 07:14 AM
  4. Replies: 0
    Last Post: 05-11-2016, 07:08 AM
  5. Replies: 1
    Last Post: 05-11-2016, 06:20 AM
