1. AC Question's Avatar
    Popup says system detected my Alpha battery 5.6% damaged and I should upload the Android patch. Occurred as i was charging phone. I am suspicious. Malware? Included a link to patch/app.
    05-11-2016 09:10 PM
  2. srkmagnus's Avatar
    Seems like Malware. Backup your data and perform a factory reset. Be careful with what you are downloading and installing onto the device.
    Rukbat and B. Diddy like this.
    05-11-2016 09:18 PM
  3. Tim1954's Avatar
    Malware. Run away
    B. Diddy likes this.
    05-12-2016 12:31 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! Agree that this is clearly bogus and malicious. Did it only appear when you were browsing? If so, it's probably just a scare ad associated with a shady website--just avoid that site. If it came up separate from the browser, then there could be some adware or malware that was installed to your phone without your knowledge, perhaps alongside some other app you installed.
    05-12-2016 07:43 PM
  1. Quick Charge - Effect on Battery?
    By tardus in forum LG V10
    Last Post: 08-23-2016, 11:42 AM
  2. Optamize Battery usage
    By jaleelhamidd in forum Samsung Galaxy S7 edge
    Last Post: 05-14-2016, 09:09 AM
  3. Really poor battery life!
    By Linzyloo88 in forum Samsung Galaxy S7
    Last Post: 05-14-2016, 01:52 AM
  4. S7E wierd srvice draining battery ?
    By Seremedy in forum Samsung Galaxy S7 edge
    Last Post: 05-13-2016, 03:27 AM
  5. Battery stats normal?
    By GS5TR in forum Samsung Galaxy S7
    Last Post: 05-11-2016, 09:07 PM
