1. AC Question's Avatar
    both are virgin mobile (my service) and are $30-$40. I need a phone for cheap so I don't worry about breaking it. All i was on my phone is half life or snes emulator and spotify/youtube music.
    05-11-2016 11:17 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Here's a comparison: LG TRIBUTE vs Huawei Union - Phone specs comparison. The Tribute is somewhat better in many areas, but the main drawback is that it only has 4 GB of internal storage (which means only about 1.3 GB available to the user). That means you can run out of storage very quickly for app installation, and the SD card won't help you. So if your apps are fairly large, go with the Huawei, which has 8 GB (not much better, but still better than 4 GB).
    05-12-2016 10:12 PM
  1. i need software update manually lg gpad7 LG-V410 from att
    By AC Question in forum LG G Pad 7.0
    Last Post: 05-22-2016, 01:05 PM
  2. lost calendar appts and contacts since new update to LG G3
    Last Post: 05-22-2016, 01:04 PM
  3. Replies: 4
    Last Post: 05-12-2016, 11:37 PM
  4. redesigned site: where's the LG Volt section gone?
    By EricSly in forum More LG Phones
    Last Post: 05-12-2016, 12:22 AM
  5. Replies: 1
    Last Post: 05-11-2016, 06:56 PM
