1. AC Question's Avatar
    My new 3 days s6 edge has screen use 70 and 60 sometimes.. Is it normal?? In general OK. Not happy with battery consumption
    05-13-2016 08:04 AM
  2. belodion's Avatar
    Welcome.
    With normal use of a phone, Screen uses most battery charge, the more so if you use a high brightness setting.
    Post a screenshot of your battery usage stats after a day's use for further opinions.
    Also, joining as a member and engaging in the S6e forum would be a good idea.
    05-13-2016 08:14 AM
  3. liakouli21's Avatar
    Can you give me the link please??
    05-13-2016 08:23 AM
  4. Tim1954's Avatar
    How much you get out of the battery?
    05-13-2016 09:22 AM
  5. liakouli21's Avatar
    What do you Mean exactly??
    05-13-2016 09:30 AM
  6. Tech-Newb's Avatar
    I usually get 12 hours of battery life with 3+ hours of screen on time. I play games for 30 min too. The battery life on S6 edge isn't that great. With QHD display and only 2600 mAh, dont expect getting a lot of screen on time.
    Posted with ❤Love❤
    05-13-2016 09:35 AM
  7. liakouli21's Avatar
    In first time I charged the phone I waited to finish and switch off by itself and after that I charged it until 100%with a slightly use... Is it a problem perhaps??
    05-13-2016 09:38 AM
  8. Rukbat's Avatar
    Charge it to 100%, then another 30 minutes. Due to the way we measure State of Charge, the instant it reaches "100%" it could be charged to 90%. Also usage has a LOT to do with battery life. If the screen is on full brightness and the mobile signal is weak, you can kill the battery fast.
    05-13-2016 01:26 PM
  1. Why are there features missing from Edge Screen?
    Last Post: 05-31-2016, 10:59 AM
  2. Galaxy S7 Edge MTP stops working on Windows 10?
    Last Post: 05-13-2016, 12:24 PM
  3. Replies: 1
    Last Post: 05-13-2016, 11:57 AM
  4. Replies: 1
    Last Post: 05-13-2016, 06:39 AM
  5. Replies: 1
    Last Post: 05-12-2016, 11:59 PM
