1. AC Question's Avatar
    I think it had some issues when i bought it so i updated the phone , and wifi is not working
    05-14-2016 12:44 PM
  2. belodion's Avatar
    Try first a Cache Partition wipe. If no go, try a Backup & Reset. Let us know if you need advice about backing up.
    05-14-2016 01:19 PM
  3. Rukbat's Avatar
    If you updated it to 6.0.1, that's a known problem and it won't be fixed until at least the next update.
    05-14-2016 08:21 PM
  1. Connect Alexa to your Samsung SmarTV
    By KahneFan in forum Amazon Echo
    Last Post: 03-16-2017, 03:20 PM
  2. And how do I turn off the Android os
    Last Post: 05-14-2016, 08:21 PM
  3. Samson S6 Android 6.0.1 how do I save a contact from phone
    Last Post: 05-14-2016, 08:20 PM
  4. Replies: 1
    Last Post: 05-14-2016, 03:58 PM
  5. Replies: 1
    Last Post: 05-14-2016, 12:23 PM
