1. AC Question's Avatar
    My Moto 360 Gen 2 is three days old. I first put the watch on charging pad to gain 100% battery life. After 20 hours on charging pad, the battery life increased to 65%. Gave up on trying to charge more life. In first three hours of use, battery life decreased from 65% to 43% with minimum data traffic. Are these symptoms of a defective battery? If so, what can be done?
    05-14-2016 01:38 PM
  2. Tim1954's Avatar
    Wireless charging is inherently slower than usb. Have you tried to charge with the unit the phone came with? If you're running marshmallow, you may have a fast change option....
    05-14-2016 03:49 PM
  3. Rukbat's Avatar
    3 hours, 22% with minimal traffic? (If you mean like a minute or two total.) Yes, either a defective battery or a defective watch.
    05-14-2016 08:37 PM
  1. Replies: 1
    Last Post: 05-14-2016, 08:53 PM
  2. my phone died, and now will not charge or turn on
    Last Post: 05-14-2016, 08:40 PM
  3. My SIM is locked. What can i do to fix this??
    Last Post: 05-14-2016, 08:16 PM
  4. Replies: 0
    Last Post: 05-14-2016, 12:47 PM
  5. How can i bypass the setup wizard on my coolpad
