1. AC Question's Avatar
    V10 is a T-Mobile variant
    05-15-2016 12:01 AM
  2. chanchan05's Avatar
    Yep. Stop installing apks from random places and get stuff from Play Store. Safer from malware.
    B. Diddy likes this.
    05-15-2016 01:26 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Agree with chanchan05. However, there are some instances where a legitimate apk file may need to be installed (like, for example, the Amazon Underground apk). You need to make sure Unknown Sources is checked on. Go to Settings>Fingerprints & Security>Unknown Sources, and make sure it's checked on.
    But otherwise, do not download and install apks from other random sites. It's not just the risk of malware--it's also the piracy that these sites promote.
    05-15-2016 01:35 AM
  1. My LG Volt 2 is stuck on talkback loop
    Last Post: 05-15-2016, 01:52 AM
  2. Install error
    By AC Question in forum Virtual Reality Headsets
    Last Post: 05-15-2016, 01:48 AM
  3. Replies: 2
    Last Post: 05-15-2016, 01:47 AM
  4. Replies: 2
    Last Post: 05-15-2016, 01:32 AM
