1. AC Question's Avatar
    I do not use my phone for video watching or listening to music. I use it mostly as a phone, text messaging, and email/gmail. Yet something is running in the background draining my battery within hours. I replaced the battery and the same thing, about 12 hours until the battery is dead. I cannot determine what updates are running in the background and really, for what I use my phone for, what updates do I really need?
    05-15-2016 10:43 AM
  2. Javier P's Avatar
    Welcome to the forums! We are going to need more information in order to help you. What phone do you have and which android version is it running? Go to settings - battery and take screenshots of the main stats, history details (after you tap on the main graph) and screen details. Also, tell us if you're using a SD card.
    05-15-2016 10:59 AM
  3. Rukbat's Avatar
    Run Greenify. Even if the phone isn't rooted (so it can kill apps automatically) it will show you what's running.
    05-15-2016 11:50 AM
  4. bobbielou's Avatar
    My battery want stay charged for more than 6 hours
    05-15-2016 02:09 PM
  5. bobbielou's Avatar
    How do I find out what running on my phone
    05-15-2016 02:14 PM
  6. Laura Knotek's Avatar
    How is your signal strength?
    Even if you don't have many apps running, if you are in an area with poor coverage than the battery will drain as the device keeps searching for a signal.
    05-15-2016 02:19 PM
  1. Doze, Samsung Optimize, Greenify, and the "Bad" Ones: Battery Life
    By KPMcClave in forum Samsung Galaxy S7 edge
    Last Post: 10-03-2016, 08:35 AM
  2. Replies: 3
    Last Post: 05-15-2016, 12:42 PM
  3. 1GB ram Ok with 20+ apps?
    By Akashroy in forum Ask a Question
    Last Post: 05-15-2016, 11:52 AM
  4. how do i get into my phone if i dont remember the pw
    Last Post: 05-15-2016, 09:50 AM
  5. Why my unread messages temporarily get marked read?
    Last Post: 05-15-2016, 09:32 AM
