1. AC Question's Avatar
    I bought a Galaxy S7 Edge on release day, and haven't had any issues with it until just recently. The battery life is draining quite rapidly while in my pocket, or overnight. I checked to see what caused it, and it says Android system. 88% in fact. I don't have many apps in general, and have disabled/uninstalled alot of them. All extra features I could find are turned off, and power saving mode is on. No connections are on except cell service, so I can't figure out what is causing it. I lost over 60% overnight last night without using it.
    05-17-2016 08:46 AM
  2. belodion's Avatar
    Try first the simplest attempted fix, a Power Off and Restart.
    If no go, get back to us right here.
    05-17-2016 11:57 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    05-17-2016 03:06 PM
  1. Are there any rugged phone cases for the Samsung Galaxy J5?
    Last Post: 06-08-2016, 09:16 AM
  2. What is the best budget mobile phone having an MHL on Type C?
    Last Post: 05-31-2016, 11:20 AM
  3. Replies: 2
    Last Post: 05-18-2016, 02:44 AM
  4. I have a vertical pink line on my s7 edge can any one help.
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 05-17-2016, 03:55 PM
  5. Excessive System Battery Drain?
    By PretoEvo in forum Samsung Galaxy S7
    Last Post: 05-17-2016, 09:17 AM
