1. AC Question's Avatar
    Hi Guys,
    I purchased the Galaxy S7 Edge from Uae and now I am back in my hometown.
    unfortunately my phone is only a month old and i just noticed that the front camera is misaligned by 1mm or so, you can see more of the black ring and the lens of the camera is more towards the right.
    Although the camera works perfect and there are no problems, should i be worried?
    I am extremely worried as the phone has no warranty in my country .
    05-18-2016 12:24 PM
  2. Tanya De la Morena's Avatar
    Welcome to Android Central! If it works I wouldn't be worried but if you want to be sure take it in to a mobile repair shop and get a second opinion, usually they will diagnose for free. If you could please sign up on our site, when your question is answered you will receive a notification and not have to search for it later. It would also give you the ability to help and share your own knowledge with other guest!
    https://passport.mobilenations.com/?...407.1450194869
    H3aTeRzz likes this.
    05-18-2016 01:10 PM
  3. Android104's Avatar
    Hi,
    I registered thanks.
    Here is a picture of it , does it look alright?
    Attached Thumbnails Misaligned front camera Galaxy S7 Edge, shall I be worried?-photo-5-18-16-10.51-pm.jpg
    05-18-2016 01:33 PM
  4. Android104's Avatar
    Hi,
    05-18-2016 01:34 PM
  5. belodion's Avatar
    I've known off-centre camera lenses. Don't worry about it.
    05-18-2016 04:09 PM
  6. H3aTeRzz's Avatar
    I also have seen that before. As long as the camera takes photos that you are happy with, I would not worry about it at all!
    05-18-2016 08:58 PM
  1. Replies: 1
    Last Post: 09-12-2016, 09:21 AM
  2. Is there too much light that will damage the camera sensor
    Last Post: 05-19-2016, 05:01 AM
  3. Replies: 1
    Last Post: 05-19-2016, 04:58 AM
  4. Samsung Galaxy Note 5 SM-N920C Dual LTE
    Last Post: 05-18-2016, 06:08 PM
  5. How do I backup galaxy S7 to dropbox
    Last Post: 05-18-2016, 01:26 PM
