1. AC Question's Avatar
    I can't get past the screen lock screen, and phone is chiming every few seconds. Time and date does display. I can't turn the phone off either. Keeps flasing between the screen lock screen and the Motorolla symbol.
    05-21-2016 09:37 AM
  2. the tall guy's Avatar
    Hi, re the screen lock - do you have it password protected? if so can you unlock it? this issue you are describing, did this just happen out the blue or were you updating the phone / restarting it etc?
    05-23-2016 02:20 AM
  3. the tall guy's Avatar
    You could also try booting the phone in to safe mode to see if you are able to start it up that way?
    05-23-2016 02:20 AM
  1. Android Pay not working
    Last Post: 06-02-2016, 09:17 AM
  2. Swipe stopped working on S7?
    Last Post: 05-21-2016, 12:49 PM
  3. Replies: 1
    Last Post: 05-21-2016, 09:35 AM
  4. Galaxy Note 4 SM-N910H Stuck on Login Samsung Account
    Last Post: 05-21-2016, 09:28 AM
  5. fingerprint sensor on S6 edge
    By sophiegriff in forum Samsung Galaxy S6 edge
    Last Post: 05-21-2016, 09:21 AM
