1. AC Question's Avatar
    Bit long this but here goes, i had the screen repaired on my Nexus 5, the shop rang me and said the battery needed replacing as it was not responding to charge, ok i said replace it (although i thought it was ok before) when i got it back i connected it to a charger and it showed the charging symbol ie the zig zag/lightening thing across the battery it wasn't charging, left it charging for 2hours , wouldn't charge up, took the back off and checked the battery and it was a new one , any ideas why its not responding anybody?
    05-22-2016 01:11 AM
  2. Rukbat's Avatar
    They disconnected something inside. Now they get to do it over, until they get it right.
    B. Diddy likes this.
    05-22-2016 12:45 PM
  1. S7 Edge Purple Haze/Flare Problem
    By John Shedrick in forum Samsung Galaxy S7 edge
    Last Post: 01-02-2017, 09:22 PM
  2. Charging/Battery Drain issue...
    By mcrvamp08 in forum Samsung Galaxy Tab S2
    Last Post: 05-27-2016, 04:13 AM
  3. Replies: 12
    Last Post: 05-23-2016, 06:44 PM
  4. Nexus 6 - Marshmallow 6.0.1 - Accidentally Deleted build.prop
    By Perseusbc in forum Nexus 6 Rooting, ROMs, & Hacks
    Last Post: 05-22-2016, 06:34 PM
  5. Problems with Viber, Facebook and Messenger
    By andronoff in forum Ask a Question
    Last Post: 05-22-2016, 12:36 AM
