1. AC Question's Avatar
    i use an advan t3c tablet. i had this problem for quite some time,i almost used 3 different earphones from the start after my original gave out no sound. when i was using my second earphone it started crackling and i heard from only the right side and from that day onward every earphone i used had to be hold or turned in a specific sweet spot to hear.plzz help me out
    is the problem in my tab or earephones?
    05-22-2016 09:38 AM
  2. Ahmetozefe's Avatar
    I had the same problem with my old phone. Every earphone I used was not working. Turned out that the little metal reseptors inside the 3.5mm jack hole were bent and couldn't percept the earphone. You might need to chance your jack socket.
    B. Diddy likes this.
    05-22-2016 10:32 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! I agree with Ahmetozefe. First, check the jack to see if there is any debris in there. Use a can of compressed air to blow it out. If it's completely clear and still doesn't work, then bring it to a repair shop to replace the headphone jack.
    05-22-2016 04:42 PM
  1. What's going to be my next phone?
    By Daniel Fuller in forum General Help and How To
    Last Post: 05-25-2016, 07:27 PM
  2. Shortcuts don't work on Galaxy S6?
    Last Post: 05-23-2016, 05:20 AM
  3. Replies: 1
    Last Post: 05-22-2016, 05:04 PM
  4. Error in contact sync - automatically adds all meailed
    Last Post: 05-22-2016, 09:17 AM
