1. AC Question's Avatar
    My phone fall into water for just 2seconds,its in on mode when it fall.And incoming call are coming,but i am unable to attend it because my touch is not working.And my battery is inbuilt battery.Can any one help me.
    05-25-2016 10:55 PM
  2. Rukbat's Avatar
    If you didn't drop it into alcohol immediately after you got it out of the water, there's probably nothing anyone can do. The impurities in the water will keep eating away at the phone for weeks, even if you get it dry inside. (It's never 100% dry, and that little bit of moisture keeps activating all sorts of salts, that eat away at copper.) Read Oh, no! My Phone got Wet! to know how to keep your next phone from getting ruined if it gets wet.
    Laura Knotek likes this.
    05-26-2016 12:32 AM
  1. Replies: 3
    Last Post: 05-27-2016, 10:44 PM
  2. Release the Ninja
    By themikishow in forum Android Games
    Last Post: 05-26-2016, 06:41 AM
  3. Why i m getting so many adds on my mobile
    Last Post: 05-26-2016, 01:13 AM
  4. How do you remove the Camera from the Locked Screen?
    Last Post: 05-26-2016, 12:57 AM
  5. How to wipe SD card?
    By love4speechless in forum Samsung Galaxy S7 edge
    Last Post: 05-25-2016, 11:38 PM
