B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,541 4,675 113 Visit site May 26, 2016 #2 Welcome to Android Central! S3, Note 3, Ace 3? Does this happen if you use a headset as well? If the phone has a case, try removing the case. Cases that block the secondary (noise-cancelling) mic can sometimes cause this problem. Upvote 0 Downvote
Rukbat Retired Moderator Feb 12, 2012 44,529 26 0 Visit site May 26, 2016 #3 If not, the first stop is the carrier - it could be their problem (echo-cancelers - a part of the phone network - do sometimes break down). Upvote 0 Downvote
