1. AC Question's Avatar
    Need help!
    05-26-2016 01:31 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! S3, Note 3, Ace 3? Does this happen if you use a headset as well?
    If the phone has a case, try removing the case. Cases that block the secondary (noise-cancelling) mic can sometimes cause this problem.
    05-26-2016 03:37 PM
  3. Rukbat's Avatar
    If not, the first stop is the carrier - it could be their problem (echo-cancelers - a part of the phone network - do sometimes break down).
    B. Diddy likes this.
    05-26-2016 04:32 PM
  1. Adios, Nexus 9 tablet. HTC has moved on
    By wshwe in forum Google Nexus 9
    Last Post: 06-06-2016, 03:34 PM
  2. Positive Experience with My HTC 10
    By VagrantSaint in forum HTC 10
    Last Post: 05-27-2016, 06:45 PM
  3. my sim card is not recieving any text messages
    Last Post: 05-26-2016, 03:42 PM
  4. Can the galaxy s6 use a 5g wifi connection?
    Last Post: 05-26-2016, 03:40 PM
