1. AC Question's Avatar
    My sound & notification is set on default notification ringtone but I do not receive any incoming calls on my phone, it rings once when a caller calls and goes to my voicemail, it does not ring on the out side. I tried everything but factoy reset.
    05-26-2016 08:42 PM
  2. the tall guy's Avatar
    Hi, do you perhaps have auto direct to voicemail enabled? there should be an option within your settings to disable it. Failing that I would suggest you speak to your service provider to see if they can assist.
  3. the tall guy's Avatar
    06-02-2016 08:32 AM
  1. Transferring mp3s to Galaxy S6 from Windows 10?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 06-02-2016, 09:04 AM
  2. Why can I only receive emails while connected to wifi?
    By leodgr81 in forum Samsung Galaxy Note 5
    Last Post: 06-02-2016, 08:39 AM
  3. Prevent screen from powering off setting?
    By sc-eauser in forum Android 5.0 Lollipop
    Last Post: 06-02-2016, 08:34 AM
  4. can't make a voice call
    By 1 alaa in forum Sony Xperia Z2
    Last Post: 06-02-2016, 08:30 AM
