1. AC Question's Avatar
    I tried almost every in settings to fix this problem lockscreen I just trying to enable the ripple affect on the lock screen but cannot figure it out.
    05-27-2016 02:11 AM
  2. the tall guy's Avatar
    Hi, do you have a pattern / pin / fingerprint security enabled on the lockscreen, if you do then the ripple effect won't work. You need to have "swipe" enabled as the screen unlocking method.
    06-02-2016 08:36 AM
  1. Icon changer free help
    By Geekduds in forum Ask a Question
    Last Post: 05-31-2016, 07:25 AM
  2. Replies: 1
    Last Post: 05-31-2016, 07:21 AM
  3. Is it best to put everything on the external card
    Last Post: 05-27-2016, 06:21 PM
  4. How much galaxy S7 edge replacement display
    Last Post: 05-27-2016, 04:36 AM
  5. Google Web & App activity not showing apps used. HTC One M7
    By Lookingforhelp8691 in forum HTC One M7
    Last Post: 05-27-2016, 01:46 AM
