1. AC Question's Avatar
    In the past, If I didn't want to answer a call, I could swipe the red phone key and the call would end. Now it doesn't work. The phone will continue to ring. I can silence it by the power button but and not ends it.
    05-27-2016 01:46 PM
  2. Javier P's Avatar
    Welcome to the forums! What device and Android version are you using? Is it a Galaxy S4? Just in case, go to settings - my device - accessibility - answering/ending calls and make sure you have the right settings enabled.
    05-27-2016 01:56 PM
  1. Verizon Galaxy Update
    By Fdeano66 in forum Samsung Galaxy S5
    Last Post: 11-06-2016, 02:34 PM
  2. Replies: 2
    Last Post: 05-27-2016, 02:30 PM
  3. Why can't I update my galaxy note 4 to 5.1.1?
    Last Post: 05-27-2016, 02:27 PM
  4. Replies: 1
    Last Post: 05-27-2016, 02:19 PM
  5. Android 6.0.1 notification panel issue on Samsung Galaxy S5
    Last Post: 05-27-2016, 01:09 PM
