1. AC Question's Avatar
    I am not doing anything with the charger, the phone has been laying on my noghtstand. This is the first time it has done this, and I have tried using different outlets. I have to have my phone for work tomorrow, and my phone wolnt stay charging long enough to actually GAIN BATTERY
    05-27-2016 10:47 PM
  2. chanchan05's Avatar
    Have you tried a different charger?
    05-28-2016 01:53 AM
  3. Rukbat's Avatar
    Sounds as if the charging port in the phone is loose. It has to be replaced. It's possible that it's a loose plug in the charger, but not very likely - the plug is a lot stronger than the port.
    05-28-2016 05:11 PM
  1. Slide/Tap/Gesture to wake up screen on ZTE DUO MAX w/ Nova Prime
    By tAKticool in forum Other ZTE Android Phones
    Last Post: 05-30-2016, 08:19 PM
  2. Replies: 0
    Last Post: 05-27-2016, 10:18 PM
  3. how to forward text messages to email on S5
    Last Post: 05-27-2016, 09:57 PM
  4. Unable to get texts on Sync since android update
    By Ellen T in forum Ask a Question
    Last Post: 05-27-2016, 09:56 PM
  5. Replies: 0
    Last Post: 05-27-2016, 09:42 PM
