1. AC Question's Avatar
    I realize this has been asked and answered, but none of those solutions worked. Things that may (or may not) be important.
    **This only occurs at my home -- I've lived there two years, problem just started, my phone is 100% in roaming -- always!! Roaming hasn't been a problem before but . . . who knows
    **US Cellular
    **Happened somewhere around the time I was forced to upgrade to Marshmallow and whatever they sent with it.
    **I have called customer service and tech 3x, they have no ideas other than roaming (I have a very strong signal at my house even though it is a roaming signal. Went to two different stores, they have nothing but the phone number to customer service. "Engineering" said they would call me back in 24 hours --- I told them to leave a message lol
    **Well-intended customer service guy blocked my roaming a few weeks, they tell it is back on now.
    **I have reviewed every option on my phone with customer service, they are all correct.
    If my phone doesn't work, I'm outta work. Can anyone think of anything??
    05-28-2016 10:18 PM
  2. Tim1954's Avatar
    I'd put my sim into another phone to rule out sim/network issues. If the the other phone doesn't work either, it's the sim, or your network (or the tower that is near you).
    If the other phone works, use it in the interim maybe. Try another sim in your device and if it still doesn't work, your settings may have slipped after update or phone has crashed. Take it to the phone shop (the provider) and go through the settings with them. Good luck!
    05-29-2016 12:45 PM
  1. The screen to my tablet is cracked, what do I do?
    Last Post: 05-29-2016, 07:50 PM
  2. Where are my edited photos going?
    Last Post: 05-29-2016, 06:20 PM
  3. Replies: 1
    Last Post: 05-29-2016, 05:12 AM
  4. How to install apps to SD card?
    Last Post: 05-29-2016, 03:51 AM
  5. Replies: 0
    Last Post: 05-28-2016, 09:38 PM
