1. AC Question's Avatar
    I just opened the front facing camera in my Galaxy J7 and it turns out to be green. It is not a completely green screen, it just looks like a green filter. The back camera is fine, but this one is not. I already restarted it and the same. I also removed the battery for 5 minutes and the camera is still green. I don't think this is a Camera App problem because Snapchat and other camera apps are also greenish. Please help me! Thanks
    05-28-2016 11:31 PM
  2. chanchan05's Avatar
    You might need to have it fixed. Looks like hardware problem.
    05-29-2016 02:11 AM
  3. Yvonne Panganiban's Avatar
    i have the same problem in samsung j7. does anyone came up with any solutions? without changing some hardware
    01-31-2017 07:08 AM
  4. anon(9983233)'s Avatar
    Oddly, this might surprise many using forward facing camera apps.. did you realize that upon shipment of your device, it has a protective covering over most of the device which needs to be pealed away before use?.. I would examine your device careful to see if there is a blue/green film over the camera lens.
    B. Diddy likes this.
    01-31-2017 07:50 AM
  1. What is the green envelope in contacts mean? [Samsung Note 5]
    By Glinx1 in forum Samsung Galaxy Note 5
    Last Post: 12-21-2016, 08:34 AM
  2. Galaxy S7 edge "mutes" calls and then hangs up
    By sgoff83 in forum Samsung Galaxy S7
    Last Post: 10-03-2016, 04:32 PM
  3. Adware Virus from the get go
    By Incarnadite in forum Samsung Galaxy S7
    Last Post: 06-10-2016, 01:59 AM
  4. Replies: 1
    Last Post: 05-29-2016, 05:12 AM
  5. Replies: 0
    Last Post: 05-28-2016, 10:23 PM
