1. AC Question's Avatar
    My s6 edge get hots everyday when I use it for only 5 mins, usually when I use snapchat it will get hotter and hotter till I have to switch off the phone and leave it to cool down or when I am just looking at Facebook or Instagram. Also, is it normal for the charging cable where it connects to the port to be very hot when charging?
    Thank you
    zita williams likes this.
    05-29-2016 02:34 PM
  2. belodion's Avatar
    The battery may be bad, or some other internal thing.
    No, it's not normal for the lead to get hot.
    05-29-2016 03:36 PM
  3. zita williams's Avatar
    hi
    no its not normal!
    my edge will at most get a bit warm when charging and if I use it a lot
    I would suggest taking it back to the supplier
    in the meantime don't leave it whilst charging if its getting very hot it could be a fire hazard
    hope you get it sorted and hope it hasn't put you off the Edge!
    belodion and Rukbat like this.
    05-29-2016 03:38 PM
  1. Replies: 1
    Last Post: 05-29-2016, 08:38 PM
  2. Why is my internal memory not saving media files
    Last Post: 05-29-2016, 08:29 PM
  3. What is the Fire Station Call out-txt-alert?
    Last Post: 05-29-2016, 08:26 PM
  4. Replies: 1
    Last Post: 05-29-2016, 02:33 PM
  5. Why does my HTC M8 doesn't turn on after factory reset?
    Last Post: 05-29-2016, 01:50 PM
