1. AC Question's Avatar
    I understand that my call log shows me the history of a number dialed once I select it. but i need to view a call history on some numbers in my contact list. is there anything i can do?
    05-31-2016 06:59 AM
  2. the tall guy's Avatar
    Hi and welcome to Android Central, the best option I think would be to call your service provider. They should be able to provide you will a call log of incoming and outgoing calls and you could filter on the required contacts you need.
    06-01-2016 02:16 AM
  1. How do I display only contacts with phone numbers? Android 6
    By hugobartolo in forum Android 6.0 Marshmallow
    Last Post: 12-01-2016, 06:36 AM
  2. Replies: 2
    Last Post: 06-23-2016, 11:36 AM
  3. having problem saving photo to sd card!
    By trexs7e in forum Samsung Galaxy S7 edge
    Last Post: 06-01-2016, 09:30 PM
  4. Replies: 1
    Last Post: 06-01-2016, 02:14 AM
  5. Can't remember google nexus 5 phone password to access phone
    Last Post: 05-31-2016, 06:06 AM
