1. AC Question's Avatar
    An update came down to my phone for Android Marshmallow yesterday. I installed it on my Galaxy S5 and didn't think much of it. Later that evening I put it in ultra power saving mode. When I got home I went to take it out but the usual option to turn it off is no longer there. The GUI looks like a hybrid of UPSM and the normal GUI but with severely restricted options like when in ultra power saving mode. I am not a programmer but I am technically savy and work in the IT field. The options I see in Android Recovery are: Reboot to boatloader, Apply Update from ADB, Apply Update from SD card, Wipe data/factory reset, Wipe cache partition, Mount /System, View Recovery Logs, and Power Off. Can I use Android Recovery to roll back the update or recover data?
    06-04-2016 07:25 AM
  1. How do i update google play services on my galaxy tab3
    Last Post: 06-04-2016, 07:02 PM
  2. What sort of replacement screen should I buy for L22C?
    Last Post: 06-04-2016, 08:58 AM
  3. Looking for an app that monitors cell reception
    By picklewheels in forum Android Apps
    Last Post: 06-04-2016, 07:05 AM
