1. AC Question's Avatar
    Every time I leave my house and come back my phone will disconnect from the wifi and say authentication problem when I try to reconnect. The only solution that I found is to restart my router but when I do that effects my tv connection as well and I have to reset my tv as well so I cannot keep doing that. I was wondering if there is anyway I can stop my phone from do this or a better solution for when it does?
    06-04-2016 11:57 AM
  2. J Dubbs's Avatar
    I would probably try a factory reset after you back up your data/contacts. Occasional factory resets can fix lots of strange problems and keep your phone working its best.
    06-04-2016 02:59 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Before you do a factory reset, you could try wiping the cache partition, which won't erase any personal data, and can help with various issues.
    Have you already tried forgetting your home network on the phone, then reconnecting?
    J Dubbs likes this.
    06-04-2016 03:13 PM
  1. Google results problem
    By kirksucks in forum Samsung Galaxy Note 4
    Last Post: 06-05-2016, 09:16 PM
  2. Problem with Google Contacts Sync
    Last Post: 06-04-2016, 06:52 PM
  3. Annoying problem with email-contacts
    By Mapras10 in forum Samsung Galaxy S7
    Last Post: 06-04-2016, 01:43 PM
  4. battery problem in my android one micromax canvas a1
    By jassi singh5 in forum Ask a Question
    Last Post: 06-04-2016, 11:44 AM
  5. why is my samsung a8 oveheating when i turn on the wifi?
    Last Post: 06-04-2016, 05:06 AM
