A AC Question Jun 5, 2016 #1 If u have a GPS app on ur phone n its constantly running with live GPS does it drain the battery or will recommend a GPS app
Tim1954 Q&A Team Jan 17, 2016 6,924 1 0 Visit site Jun 5, 2016 #2 GPS will search for satellites regardless of what app you use, and that will drain battery fairly fast. if you're in a car, plug it in cigarette lighter is what i usually do... Upvote 0 Downvote
