1. AC Question's Avatar
    If u have a GPS app on ur phone n its constantly running with live GPS does it drain the battery or will recommend a GPS app
    06-05-2016 01:00 AM
  2. Tim1954's Avatar
    GPS will search for satellites regardless of what app you use, and that will drain battery fairly fast. if you're in a car, plug it in cigarette lighter is what i usually do...
    06-05-2016 02:46 PM
  1. Lg G4 Double tap and glance view not working.
    By Stylazation in forum LG G4
    Last Post: 07-24-2016, 05:12 PM
  2. ZeroLemon extended battery for V10
    By datum9 in forum LG V10
    Last Post: 06-06-2016, 03:31 PM
  3. PC Speakers and TV optical sound output
    By df79transam in forum Google Chromecast Audio
    Last Post: 06-06-2016, 09:39 AM
  4. Replies: 1
    Last Post: 06-06-2016, 08:20 AM
  5. Replies: 0
    Last Post: 06-04-2016, 10:41 PM
