1. AC Question's Avatar
    Something very wired is happening with my (s5-smg900h) when i bought this phone i lost about 3~12% of battery overnight but for some reason I'm losing 80% battery now the the battery is fine under use waching videos playing games it drains normally but at nightit drops to much and the most weird part is when i wake up at ex 6AM and check the phone it stops drining battery.
    06-06-2016 02:10 AM
  2. Tim1954's Avatar
    If you go into settings >battery >battery usage it should give you a breakdown of what's using your battery.
    06-06-2016 02:34 AM
  1. What is typical g4 battery life?
    By timmmithy in forum LG G4
    Last Post: 06-12-2016, 01:40 PM
  2. Charging Problems and Battery Drain
    By BamaDave in forum Samsung Galaxy S6 edge+
    Last Post: 06-09-2016, 06:49 AM
  3. Orange led blinking after replacing battery
    Last Post: 06-07-2016, 06:32 AM
  4. Replies: 2
    Last Post: 06-06-2016, 04:11 AM
  5. Dead Battery Or Broken Port Insigna 10.1
    Last Post: 06-05-2016, 10:15 PM
