1. AC Question's Avatar
    My Samsung Galaxy S6 edge plus is draining it's battery from the Android os. My phone has been fine than a few months ago it started draining the battery. Then it stopped. Now it started again a few days ago. How do I fix this. I've tried and nothing seems to work. Please help.
    06-07-2016 12:31 PM
  2. belodion's Avatar
    A simple Reboot or Cache Partition wipe will sometimes fix that, or it will settle eventually by itself. Otherwise, consider your Awakes, Syncing, Background App activity, and Location Reporting.
    06-07-2016 12:48 PM
  1. Replies: 11
    Last Post: 07-21-2016, 05:09 AM
  2. Replies: 4
    Last Post: 06-08-2016, 05:16 AM
  3. Replies: 1
    Last Post: 06-07-2016, 06:03 PM
  4. Replies: 1
    Last Post: 06-07-2016, 12:13 PM
  5. Replies: 0
    Last Post: 06-07-2016, 12:04 PM
