1. AC Question's Avatar
    I can connect to the internet just fine when the wifi option is on but when I try to use my data internet it doesn't work. I bought this unlocked phone a few days ago from amazon. It works perfectly fine, calls/texts, except for the data/4G connection. I didn't have this problem with my old windows phone so I'm not sure it's my carrier. The problem is just on my new android phone. Could it be the settings or do I have to go to my carrier so they can activate my internet?
    Any help would be appreciated .
    06-10-2016 02:10 PM
  2. Laura Knotek's Avatar
    Welcome to Android Central.
    What carrier do you have?
    You might need to edit the data APN on the device.
    Rukbat likes this.
    06-10-2016 02:14 PM
  3. lety26's Avatar
    Thanks.
    Tmobile. where can I find the data apn setting on the phone?
    06-10-2016 02:30 PM
  1. Will replacing the battery wipe out my data?
    By tmann202 in forum Moto X (2013)
    Last Post: 06-13-2016, 03:04 PM
  2. Factory reset - locked out of phone
    Last Post: 06-10-2016, 06:55 PM
  3. Unlock background data.
    Last Post: 06-10-2016, 02:56 PM
  4. Replies: 1
    Last Post: 06-10-2016, 02:47 PM
  5. Anybody else with this problem? Or anybody who can help!?
    Last Post: 06-10-2016, 02:20 PM
