1. AC Question's Avatar
    I was trying to replace my usb charging port flex cable, and there was another one attached to it towards the bottom, it has a little strip that attaches further into the phone under the plastic. I accidentally ripped it off thinking it was on there so someone could tell if you messed with it (like a warranty sticker). Can anyone help me identify it? There's a magnetic gold strip that connects the two cables. Also, am I screwed for pulling it off? It's a cheap phone and I don't want to spend a lot to fix it.
    06-10-2016 06:35 PM
  2. the tall guy's Avatar
    Hi, how did you get on with the above, did you manage to fix the phone?
    06-16-2016 04:24 AM
  1. My Android phone is dead!
    Last Post: 06-16-2016, 04:22 AM
  2. Galaxy S7 Active won't stay locked
    Last Post: 06-11-2016, 05:32 AM
  3. why does play store make me buy mindcraft for all my defices
    Last Post: 06-10-2016, 10:08 PM
  4. Replies: 2
    Last Post: 06-10-2016, 09:54 PM
  5. My BSmolibe funk have a monkey virus how can i fix this?
    Last Post: 06-10-2016, 06:38 PM
