1. AC Question's Avatar
    No more detail needed the initial question is what I need to know in its entirety
    06-12-2016 04:43 PM
  2. sfoLAX's Avatar
    Hello. Personally I would need more
    If you're plugged in to an outlet you are charging !?
    It will not say Outlet Charging.
    You can charge via the usb port on the S6 via an outlet using a one piece charger with attached cable as sometimes the case with Samsung's dependent on region; with a charging block and separate usb cable, or from a pc / laptop usb port.
    If you have upgraded to Android 6.0, the USB connection will now be in charging mode only, so if you want to transfer files or photos you would have to change the USB connection mode to MTP or PTP via the notification shade.
    That's it. All I've got. No more answer needed. That's all you need to know in my entirety!
    06-12-2016 05:43 PM
  1. Samsung Gear VR making phone crash/not charge
    Last Post: 02-09-2017, 01:43 AM
  2. Zeepad is saying unfortunatley WeQR has stopped
    Last Post: 06-12-2016, 07:44 PM
  3. Replies: 0
    Last Post: 06-12-2016, 04:39 PM
  4. Replies: 0
    Last Post: 06-12-2016, 04:17 PM
  5. Can I flash a rom using my otg on my nexus 7 2013
    Last Post: 06-12-2016, 03:44 PM
