1. AC Question's Avatar
    Hello
    I would like to know some infos about the battery consume of Samsung.
    I own a Samsung Galaxy J5.
    My phone is new so I use it since 2 weeks ago or less.
    I started use at 05.58 and battery was at 90% (I just navigate in this forum)
    Now here it's 06.05 and battery is already at 89%.
    Is it normal this fast consuming of the battery?
    I woke up at 5.00 am and was at 100% charged and now its 06.07 and battery is 89% already. Is this normal?
    I also activated an app "eye protector" and luminosity it's really low.
    Im using internet via wi fi and its in offline modality.
    I would like to ask others how many minutes you experiment the consuming of your battery?
    I read a battery should be durable until the end of day..but if in few minutes it already go down so fast I doubt it will durable untill 24 hours..
    Thanks for the info...
    ps even if I shut off the connection internet wi fi,and I just read . it doesnt seems things changed a lot... the most consume of battery ot says the manager is the screen....but the lightness is at minimum already....
    and even eye protection app....
    thanks for infos..
    06-14-2016 11:10 PM
  2. belodion's Avatar
    Can you post a screenshot of your battery usage stats at the end of a day's use? Set the screen brightness to whatever is comfortable to use, rather than a low setting. Tell us also what your screen-on time is at the end of the day.
    For feedback about other users' J5 battery, I recommend posting in that forum, which you'll be able to do when you join as a member.
    06-15-2016 06:28 AM
  1. Turn off fast photo
    By Kasnotiek in forum Huawei P8
    Last Post: 09-04-2016, 03:25 AM
  2. What is wrong with my LG G3?
    By Arianna Isabella in forum LG G3
    Last Post: 06-22-2016, 04:33 PM
  3. Why does my battery life drain so fast? Galaxy Note 2
    Last Post: 06-14-2016, 11:31 PM
  4. 12040#9345646 found in call logs what kind of number is this
    Last Post: 06-14-2016, 10:14 PM
  5. Replies: 1
    Last Post: 06-14-2016, 09:32 PM
