1. AC Question's Avatar
    Hi I have award issue i own a samsung s7 edge ... when you go to the edge function and theres an apps edge screen says there is a update in user left but when i click on update does nothing in samsung store anyway to get rid of this ...international version
    06-15-2016 02:59 AM
  2. Kwonzilla's Avatar
    I'm having the same issue, and I have the U.S. version (T-Mobile). How do we update the Apps Edge?
    06-20-2016 10:46 AM
  3. Kwonzilla's Avatar
    Oh I figured it out. I had Galaxy Apps disabled in Applications Manager. Enabling it allows the update to work.
    06-20-2016 10:55 AM
  4. Stalonage's Avatar
    That's good to know , I'm getting the phone soon and I usually disable a million apps when I get it and that would have definitely been one of them.
    06-20-2016 10:57 AM
  1. Moving apps to SD card. LG g5
    Last Post: 08-31-2016, 05:27 AM
  2. Verizon S7 Rooted!
    By xocomaox in forum Samsung Galaxy S7 edge
    Last Post: 07-05-2016, 09:51 AM
  3. text to voice set up on the Samsung Galaxy Edge S7 G935F
    Last Post: 06-15-2016, 12:59 AM
  4. FPV app over WIFI
    Last Post: 06-15-2016, 12:31 AM
  5. How do I add Yahoo email account to Samsung phone?
    Last Post: 06-15-2016, 12:12 AM
