1. AC Question's Avatar
    Galaxy S4
    No sound at all...
    Phone will not ring
    No notification sounds
    No audio on videos of any kind
    The only audio I have is that I can hear who I am talking to on the phone.
    Audio just stopped even though audio is at "full blast" in all areas.
    This is the second time I've lost audio for no apparent reason. The last time it happened, the audio finally, after a few days, magically came back...but not this time!
    What in the world has happened and how do I fix it??
    Help!
    Thanks!
    06-15-2016 04:37 AM
  2. belodion's Avatar
    Try first.a Cache Partition wipe.
    06-15-2016 05:54 AM
  3. David Jorgensen's Avatar
    Had the same problem with an LG G3 and solved it. @belodion if you mean Settings -> Smart cleaning -> Temporary files -> clean it did not work. Calls and notifications were not making a sound or vibrating. Screen notifications worked - could see an incoming call. A simple restart did not help. **Power off, then power on fixed it**
    06-18-2016 12:38 AM
  4. J Dubbs's Avatar
    I'm having the same problem with my brand new Moto X Pure.....it upgraded from lollipop to Marshmallow out of the box and now no bluetooth or sound. I'm doing a factory reset to see if that fixes it, that's what everybody's recommending.
    06-18-2016 01:38 AM
  1. Is the MM bootscreen supposed to make a sound?
    By rokemsokem in forum Samsung Galaxy S5
    Last Post: 06-16-2016, 04:17 AM
  2. Replies: 1
    Last Post: 06-15-2016, 07:59 AM
  3. HTC one M8 running and eating up top up allowance
    Last Post: 06-15-2016, 05:56 AM
  4. Replies: 0
    Last Post: 06-15-2016, 04:12 AM
  5. My True Caller not searching name while on call, why?
    Last Post: 06-15-2016, 03:19 AM
