1. AC Question's Avatar
    I used kingoroot to root my phone ( Samsung Galaxy S5) and at 99% it got stuck after "downloading requiste files" and after that my Samsung Galaxy screen now only shows
    "Recovery booting....
    Recovery is not seandroid enforcing
    Set warranty bit: recovery
    Samsung Galaxy S5
    Power by Android
    PLEASE HELP I've already unplugged it and restarted it but it just shows the same thing oh my god I'm in so much stress please.
    06-15-2016 07:04 AM
  2. VigneshB's Avatar
    You can try to perform a reset on your phone, though it is highly ;likely that would need to flash back the stock ROM.
    To reset, in the power off mode hold the Volume up button, the Home button, and the Power button together until you see the Android on screen. Use the volume keys to select wipe data / factory reset option. Use the power button, and then the volume down button to select confirm and again the power button.
    If it fails, you can flash back the stock ROM using this tutorial - [Guide][Samsung] How to flash Stock ROM via ODIN with the New Interface
  3. VigneshB's Avatar
    06-15-2016 07:12 AM
  1. Need help looking for a browser
    By Raestloz in forum Browsers
    Last Post: 07-18-2016, 07:35 AM
  2. Verizon S7 Rooted!
    By xocomaox in forum Samsung Galaxy S7 edge
    Last Post: 07-05-2016, 09:51 AM
  3. Suspected Malware Problem
    Last Post: 07-03-2016, 02:29 AM
  4. Please help! my Acer Talk 7 Model b1-723
    By parengJames in forum Android 5.0 Lollipop
    Last Post: 06-15-2016, 07:47 AM
