A
AC Question
My Note 4 is an unlocked SM-910F version, about 20 months old. For the last few months (possibly after the 5.0.1 update?), I have been having this problem where the battery drains normally until going below 10 to 30% (it varies), and then the phone abruptly shuts off. When I turn it on again, the battery says 0% and it immediately shuts off. Sometimes after the initial shutoff it will go into a boot loop (so it clearly has a bit more juice than 0%!).
I figured it could be a bad battery, but my wife bought her Note 4 at the same time and hers also has this issue (she also updated). This makes me wonder if it is a software problem, as I would think the odds of two batteries going bad at the same time are slim. I have tried "calibrating" by charging to 100% with the phone off, but this does work. I have also wiped the cache and did a factory reset (which apparently does NOT remove the major Android updates).
Has anyone experienced a similar problem and found a solution that doesn't involve rooting the phone or sending it back to Samsung to have them wipe Android 5 off?
Cheers
Cheers
