1. AC Question's Avatar
    My S6 microphone stopped working during a phone call. I am still able to use the speaker phone while making phone calls or my bluetooth without an issue. I've done a factory reset but cannot take the phone apart to look at it. I've also used a paperclip to try to clean the microphone hole but it still doesn't work.
    06-16-2016 11:39 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! If you're pretty sure the mic opening is clear, then the mic itself has probably failed. Is it still under warranty?
    06-16-2016 12:20 PM
  1. Is there a noise surpriession issue with this device on marshmallow?
    By mikeyboy80 in forum Sony Xperia Z3 Compact
    Last Post: 06-19-2016, 05:07 AM
  2. Samsung Pay
    By raqball in forum Samsung Galaxy S7
    Last Post: 06-17-2016, 12:09 PM
  3. Why aren't I getting notifications on Galaxy S4?
    By Jeffh29 in forum Samsung Galaxy S4
    Last Post: 06-16-2016, 06:14 PM
  4. Can I disable wifi on android via settings?
    Last Post: 06-16-2016, 05:25 PM
  5. Replies: 1
    Last Post: 06-16-2016, 12:35 PM
