1. AC Question's Avatar
    I have a Umi Zero on EE in the UK. I can connect on EDGE, but as soon as the connection changes to a faster mode I lose registration the network even though the phone still sees signal from the carrier. This happens in all locations with signal strength having no effect. I am checking signal type, strength and tower location with Cell Info Lite. The carrier is unable to help.
    If I change the phone from WCDMA preferred to GSM Only I can hold the connection, but obviously it stays on EDGE.
    I am running the official Umi ROM V3.10, but the problem also occured on the V3.06 ROM.
    06-17-2016 09:56 AM
  2. dpham00's Avatar
    I would try the sim in another phone to see if you still have the same problem
    06-17-2016 12:30 PM
  3. Fivescrock's Avatar
    The SIM works in another phone, and a SIM which was in that other phone fails in the same way in mine!
    06-22-2016 06:02 AM
  4. belodion's Avatar
    Welcome as a new member.
    The device may be faulty. Contact the manufacturer's customer support.
    06-22-2016 06:40 AM
  1. Battery life problems with the screen
    By Arnaud Saget in forum Samsung Galaxy S7 edge
    Last Post: 06-21-2016, 08:52 AM
  2. Replies: 1
    Last Post: 06-17-2016, 12:51 PM
  3. Replies: 2
    Last Post: 06-17-2016, 09:13 AM
  4. Replies: 1
    Last Post: 06-17-2016, 08:20 AM
  5. Replies: 1
    Last Post: 06-17-2016, 07:49 AM
