1. AC Question's Avatar
    I installed this app:
    https://play.google.com/store/apps/details?id=com.blizzard.bma&hl=en
    It now says installed when I click that link. However, it's absent from my apps tab and when I go to settings > applications to try to uninstall it I can't find it there either. I had a similar problem once before with a banking app that couldn't be found or used, but that time I was able to uninstall.
    This problem is very odd and very frustrating. I already tried googling for solutions but nothing similar came up. Any help would be appreciated.
    06-21-2016 04:33 AM
  2. the tall guy's Avatar
    Hi, when in the play store does it not give you the option to open the app and uninstall it? Are you checking all of the app drawer, baring in mind it might not be in alphabetical order and the app might be at the very end? also are you running a custom launcher?
    06-28-2016 03:37 AM
  1. Samsung Galaxy S2 T813N w/ Android 6.0 Marshmallow
    By sharpdroid in forum Samsung Galaxy Tab S2
    Last Post: 06-22-2016, 08:31 PM
  2. Replies: 1
    Last Post: 06-21-2016, 03:10 AM
  3. Phone not lighting up or unlocking when call comes
    Last Post: 06-21-2016, 03:08 AM
  4. Replies: 0
    Last Post: 06-21-2016, 01:23 AM
  5. Samsung Galaxy Tab S2 WiFi keeps disconnecting.
    Last Post: 06-21-2016, 12:29 AM
